Hi @seaiz, I saw your PM first but should repeat my answers here so everyone can benefit.
Re MQA streaming problems:
Those MQA dropouts are caused by Tidal. Sometimes you can get the same problem at the same point in a track every time, proving there is a problem in the copy of that track on the Tidal server. In other cases it's just a problem with Tidal's overall stream, and that is usually happening on Tidal's network (if your own local download speed and quality is OK). I believe that what it should do is show 48k at first, and then become fully unfolded to 88.2, 96, or 192k, sometimes so fast you may not see the 48k displayed on the DAC's screen. What it does instead is somehow lose the bit perfect quality it needs. This is not caused by your DAC.
Re MQA local playback (which you asked about in your PM):
To play local MQA files from foobar2000, you need to do the first step in the manual's instructions for DSD Playback setup: installation of the foo_out_asio component. Then MQA local file playback should work. While you're at it, you can continue the setup so you'll be ready for DSD files. The instructions are also missing this information about the settings for DSD256: in the Pro-Ject control panel, your Buffer Settings must be adjusted so that USB Streaming Mode is higher than "Safe" and the ASIO Buffer Size is at maximum.
OK?
