JohnW
pfm member
John,
that makes great sense!
Will the FDAC have an analogue pre-amplifier?
Uwe
It depends upon our skill / results of our FPGA work - lets see where we are in 6 months time with the MDAC2 ESS / Discrete DAC boards.
John,
Uwe
Does "FPGA Modulator" mean included DSP capabilities?
Or is that a different step?
Personally, i'm increasingly convinced that I would like to do room correction sooner or later, in not even digital x-over...
Wow, great new ideas John
Sure looks like it makes a lot of sense to forget about the ESS DAC's altogether and really spent time on discrete only designs.
Too be honest, coming this far you shouldn't compromise, I think all involved will agree.
Yes, this exactly
Yes this has been my point of view for awhile now - lets see where the MDAC2 "developments" lead the FDAC - the FDAC will encompass all the advances brought by the MDAC2 and go further with internal PSU and Tube stage etc.
As the MDAC2 starts to finally come together - the path to FDAC is also clearer, the MDAC2 will be released in "Stages":-
MDAC2 with Dual ESS9028PRo DAC PCB
MDAC2 with "Dacapo Anniversary" Discrete DAC
MDAC2 with "Dacapo Anniversary" Discrete DAC + FPGA Modulator
FDAC based on MDAC2 with "Dacapo Anniversary" Discrete DAC + FPGA Modulator and Tube output stage.
Each step of the MDAC2 path will (hopefully) be user upgradable by exchanging internal PCB's.
Also the MDAC2 external PSU will be offered in two versions, the initial design will be "Just" a HQ PSU, with a later version with internal CDRom slot loader + SDD Drive bay and front panel mounted USB port (for USB Flash drives) to form a complete solution with the MDAC2+ Streamer.
The discrete "Dacapo" DAC will support native DSD to 512 (64, 128, 256 & 512).
I think that Roon claim that they do up sampling and volumen in software without SQ loss all processing is done in 64bit.Yes, this exactly
I'm still not sure that's the solution for DSD - I fear any processing of the Native DSD will destroy DSD's advantages... MDAC2 will give us possibilities to try...
No, this simply cannot be - DSD's ONLY benefit is better Time domain performance and the ONLY way to preserve its time domain and perform any kind of "processing" is to throw the signal into a modulator operating significantly faster then the raw input DSD stream.
ESS can do this as its modulators are clocking near 100MHz - but any Roon software processing is not going to be anywhere near this rate.
I suspect they convert to some form of PCM then back to DSD which is criminal to the time domain fidelity of a native DSD file.
There's no other magic pill here, you can only process DSD with a far faster modulator if you want to prevent any time domain corruption of the original data.
Closer to the time Jarek will work on the PSU once hes completed some other projects.
But isn't the standard practice for mixing and mastering DSD in the studios to use DXD (which is 352.8k PCM) as the internal format in systems like Merging Pyramix workstations and their ilk, even for stuff labeled "pure" or "native" DSD?
TPS7A4700 Ultralow-noise (4µVrms) Power Supply ??
No, they can be easily bettered by discrete designs and no good for our application (to low power dissipation, crappy PSRR, poor B/W, too low input voltage).
I am not convinced pmd200 would be better than the dual ess9018, is there any measurements or blind listening tests proving it?
Value for money at that price point ?
Yes i was planning to go with the ess boad but i may change my mind, this is why i asked if there was any measurements proving the PMD to be better. You stated the pmd had 10db worse S/n ratio but it may be better in another area(such as better sounding filter).Quite simply the PMD100 with discrete DAC I designed in 1991 sonically blows away both ESS9018 & Dual ESS9038Q2M based DAC designs.
But why worry? - if it upsets your facilities then just go for the Dual ESS9028Pro DAC board and be happy
