Swamp Thing
Remainiac Terrorist
Yeah it's a shame the government had to pay all those billions to engineers to design a hole in the ground, else there might be some money left to buy the hospital a battery.
This is an engineering problem. The system supplying the power needs to be able to react to changes in demand and supply and balance these. Renewables, especially the Variable Renewable Energies (VRE) introduce second by second changes in supply - as in wind and sunlight - and then you obviously have the same in demand, although this can be better managed such as by the strategies I mentioned upthread.
This is from the ravingly pro-renewable international group IRENA, and may help explain that we need to generate something that a) is always on, and b) can be used to vary supply to balance against demand and the variability in supply of VRE.
https://www.irena.org/publications/2018/Nov/Power-system-flexibility-for-the-energy-transition
Batteries cannot fix this problem. The way they work, the number you would have to have to have creates a worse ecological problem than the generating options, the elements required to support the production of them are not available and in the short to medium term the technology is not there yet.
This required "baseload generation" could be gas, oil, nuclear or maybe potentially biofuels - but that may not be sustainable with agriculture. So it is poisoned air (will kill people) or radioactive waste (might kill people if managed badly). Or Hyrdo if you live in Norway. Not that helpful in Suffolk. And the goals of zero carbon by (or hopefully long before) 2050 are not served by continued fossil fuel use.
