Wall mounting heavy monitors?
Discussion in 'audio' started by Bluedroog, Sep 30, 2019.
  1. Bluedroog
    Bluedroog pfm Member
    due to practical considerations I’m considering wall mounts for a pair of Event Opals, I believe they’re 27kg, so not light. Having only used brackets for light bookshelf passives years ago, I’m a bit nervous.
    Obviously I need something pretty heavy duty and to use appropriate screws, what else should I be aware of and can you recommend some mounts up to task? I emailed DV247 but they recommended some which when I read the specs were only up to 7kg.
    With thanks
  2. Vinny
    Vinny pfm Member
    Solid walls?
    If you have, the only hassle is working-out what fixings to use, of which there are many suitable ones.
    If you haven't……………………… you are at least going to have to find the studs.
    BEWARE - some fixings for stud walls claim VERY heavy loads capability, but they will be for shear loads. Speakers will exert a great deal of pull-out force.
  3. JensenHealey
    JensenHealey pfm Member
    Not an expert. I would look at the almost flush mountings for heavy mirrors. Pain to install, as you have to get them perfectly lined up. BUT if you can mount one at each rear corner you could carry a huge load easily. From a mechanical point of view of they are held tight back to the wall there is less leverage away from the wall.. the more you can transfer the load straight down the wall with less pulling away the better.
    Another approach would be to put a small square batten on the wall under the speaker and sit the back of the speaker on that. Whatever you use on the top (those mirror mounts again would be invisible) would not actually carry much load - just stop the speaker tipping away.
    Both of these ideas presuppose that you have a solution for getting the wires connected - and if the connectors are proud of the rear then that is unhelpful!
    Mike Reed likes this.
  4. Vinny
    Vinny pfm Member
    Mirrors will produce almost all shear load!!! Very little pull-out - BEWARE.
    All the weight of speakers is at the front, almost, not close to the wall..
    A quick google and the only brackets to take 30kg so far require top-hat fixing.
  5. Whaleblue
    Whaleblue Southbound
    OP, does the situation allow for a framework attached to the wall, running to the floor - gallows style? Just a thought, and do your own calculations!
    Or a platform hung from the ceiling - assuming good strong joists are in helpful positions?
    Vinny’s dire warnings are to be heeded!
  6. h.g.
    h.g. pfm Member
    If they are studio monitors then whoever makes them plus some third parties will likely sell brackets for mounting. Here are some for a similar speaker.
  7. Paul Burke
    Paul Burke pfm Member
    An option is to have a local company make you something, try a metalworkers, that’s a lot of weight to hang if they’re going to be off the wall a bit.
    If you have something solid to fix to, could use something like m10/m12 threaded bar, drill slightly wider hole and let it set with a 2 part resin/chemical anchor it’s called in the trade, can find it easily enough in most decent merchants.
  8. Big Tabs
    Big Tabs hearing problems
    Microwave L-brackets. Some fold, some are solid.
    I used something like it for a glass shelf to hold a Roksan k3 amp (14kg+) - I think the ones I got are good for 40kg ++ They feel rock solid, used 4"+ huge screws with a bolt head.
    I would be tempted to look in B&Q, but I am sure there are expensive HiFi branded mounts that are available.
    Something like this? there is a lot of choice
    https://www.amazon.co.uk/Microwave-...ateway&sprefix=microwave+wall,aps,152&sr=8-11
    jamington2004 likes this.
  9. jamington2004
    jamington2004 pfm Member
    I hung mine from the ceiling joists and angled them down. A basic 1 inch square box section of steel about 1m long, with a steel plate welded on at the top to take a couple of dirty great big coach screws into the ceiling joists!
    Then at the speaker end a connector to take the speaker plate with a hole through it to take an m8 bolt. It also allows the speakers to swivel side to side
    Then you can have any speaker plate you need made up and just attach them into the permanent ceiling bracket.
    I am damned if I can get into flikr but can email photos of the design if interested :)
    Big Tabs likes this.
  10. Mike Reed
    Mike Reed pfm Member
    In my loft I have a heavy duty microwave/TV/what-have-you metal wall shelf which is movable in the horizontal plane. The wall fixing is similar to the above link, but this has an articulated arm and platform/tray. Well known make but can't remember it. There are a number of ways of getting heavy-ish speakers on a wall, some of which have been mentioned, though you'd struggle with stud walls, as aforesaid up post.
    However, the only speaker which will perform properly against or very close to a wall is an infinite baffle one (sealed box). Ports are out. Unless you're very lucky, you'll also need to angle them slightly horizontally, so they need to be a few inches away; likewise for cable entry too.
  11. Rug Doc
    Rug Doc pfm Member
  12. Operajulian
    Operajulian Opera Julian
  13. jamington2004
  14. Vinny
    Vinny pfm Member
    Apply some simple mechanics to that comment.
    The studs will only be wide enough to take one screw across their width. The assembly - speaker + bracket - will produce what is essentially a turning moment, trying to tip away from the wall - only the top-most fixing will be under tension/pull-out force i.e. the ENTIRE load will be taken by the topmost fixing. Anything below the top-most will just be location devices and take no tension, and probably no shear load whatsoever.
  15. jamington2004
    Hmmm - I’m not an engineer but I am sure a much higher %age of the load than zero must be taken by the other fixings? :)
    Especially as the mounting arm is located towards the bottom of the wall plate?
    And the function of the others would also be to stop the bracket from pulling away from the wall, which would take quite some considerable force if fairly long wood screws were used?
    Looking at the detailed instructions it looks like at least 4-6 screws could go into the stud (2 at the top, 2 at the bottom, and 1 or 2 in the middle)
  16. Vinny
    Vinny pfm Member
    Let's just leave it at the first comment :)
  17. jamington2004
    Ha! Fair enough! :)
    Engineer or not - I would still give it go myself with 5 or 6 screws into the stud!
  18. h.g.
    h.g. pfm Member
    The force on the bolts will be at an angle which varies with height. The vertical component will be shared. The horizontal component will get larger the further the speaker is from the wall. It will pull on the top screws and push on the bottom. The former needs some consideration beyond what a bracket can hold in terms of specified weight.
  19. jamington2004
    Yeah I thought the specified weight limit of brackets is all about whether the metal the bracket is made of will bend / snap under pressure. Nothing to do with whether the fixings will come away from the wall
  20. cctaylor
    cctaylor pfm Member
    If a stud wall, the only safe solution is to strip the plaster board and replace it with some thing much stronger such as block board with loads of screws into the studs
    Then you can use suitable hollow wall fixings with confidence.
