You could try something along the lines of post #448.
Ok,
Let us assume that something USB cable related IS changing the output of the DAC.
The first thing to do is to analyse the output in the analog domain. Which we do with the 2 USB cables which have been reported as being the most different.
And we find that the DAC output is within the specified bounds for the DAC in qustion. This immediately throws very strong doubt on the original assumption. It aslo effectively shows that if the same sequence of 0's & 1's is fed through the same DAC, you get the same output. Not suprising.
So lets try re-digitising the output from the DAC using the 2 USB Cables and do a bit by bit comparison. They will almost certainly be slightly different due to the random nature of noise in the analog output stage of the DAC. But we can do further analysis to determine if the differences are more significant than that.
If this analysis shows that the output has changed to a greater extent than random noise variation would account for, something is happening. If random noise can be shown statistically to account for the differences, something still may be happening, but it's at a level lower than the random noise level of the DAC.
The question then has to be asked if differences of this magnitude are audible.
We also, at this stage have to start questioning the original assumption.
And here, we are up against the old double blind test again. To do this properly is going to be very slow & tedious, and a sufficient no. of test subjects will have to take part to make the results statistically robust. Not cheap.
Or we can apply Occam's razor and weigh the possibility of unknown physics existing in a field as well studied & established as physics being at play to such an extent that the relatively crude discrimination of the human hearing mechanism can dedtect it but that far more sensitive instruments cannot, or that we are dealing with very well researched and documented psychoacoustical effects. Which one does a reasonable & rational person favour?
Chris
O
