Here's some info on the USB cable spec followed by some info about what I've tried. Note that only the data wires are twisted and even this is optional for low speed transfer.
USB requires a shielded cable containing 4 wires.
Two of these, D+ and D-, form a twisted pair responsible for carrying a differential data signal, as well as some single-ended signal states. (For low speed the data lines may not be twisted.)
The signals on these two wires are referenced to the (third) GND wire.
The fourth wire is called VBUS, and carries a nominal 5V supply, which may be used by a device for power.
The impedance spec is rather wide 76.5 Ω minimum; 103.5 Ω maximum
I've seen people state that the power lines being adjacent to the data lines causes uneven impedance, of course the longer the cable the worse this becomes. This many be the reason for the wide impedance spec.
Here's a generic USB cable layout:
It's likely many of the audiophile cables use very individual layouts.
Here's an audiophile cable layout by Wireworld:
What started me comparing USB cables was when I tried an A to B adapter from laptop to DAC. I found the sound was different to a typical 2m generic cable. I then tried shortened cables and found these to be better
than the longer ones. My best cable which was (close in sound to the straight-thru adapter) was from a Seagate drive. I tried some audiophile cables but found they sounded different again but none
were in totality to my liking.
A to B adapter:
So far I'd found I prefered shorter cables and the adapter best of all. I then made what is a non-compliant cable missing the VBUS wire and I've no idea what the impedance is, this sounded the same as the A to B adapter:
I've tried 30cm and 50cm cables without the VBUS wires, these sound the same as the very short cable I made.
- Did I do any blind testing? No.
- Can I be sure what I find in my system is globally applicable? No.
- Am I sure enough that All USB cables don't sound the same? Yes but I can't define all the required environmental variables.
- Are differences in sound due to digital data being corrupted? I doubt it.
- Should anyone believe me? No, they should try some cheap as chips experiments for themselves.
