Tannoy Chatsworth 12" MG rebuild advice.
Discussion in 'classic' started by awkwardbydesign, Feb 26, 2021.
  1. awkwardbydesign
    I've started making the curved sides. I couldn't get 4mm birch ply locally, so I am making them like barrels, with staves. 3mm hardboard inner face, then the staves (cut at 3.75 degrees) and then a 3mm hardboard outer skin. One glued, another drying.
    This is the shape. 33mm thick front, 24mm top and base. 24mm back, 24mm sides. 18mm cross braces, bitumenised felt damping, black foam grilles, veneered panels, dark brown leather front, vertical oak side strips. Most of which I have, so I will be using it.
    tonerei likes this.
  2. awkwardbydesign
    All 4 sides made, and one pair screwed to the top and bottom plates, to maintain the curve.
  3. awkwardbydesign
  4. awkwardbydesign
    And as I can't safely lift them now...
    simonpyeman likes this.
  5. awkwardbydesign
    Now making the blocks for the slot vents. 48 needed, 20 done. 10mm x 144mm in 18mm and 9mm ply, to allow for tuning. 4 slots per cab, calculated as 81mm deep, plus 28mm fronts for 109mm total, plus extras, up to a max of 127mm.
  6. awkwardbydesign
    Both fronts slotted, and one set of blocks screwed on. Total slot depth 109mm, inc front panel. Removable to adjust, plus or minus.
  7. awkwardbydesign
    And this is how it fits together.
    Fatmarley likes this.
