Surely this is a non sequitur. What has this to do with warranty?Rule 5 sounds a bit dodgy to me. If your existing system has a fault, and you can show that the fault doesn't exist with other equipment, then surely it's rational to buy new equipment.
- Richard.
It was a figure of speech.
It will if you design the run-in correctly.A serious walk on new boots will give you blisters as big as a Naim Nait Two's power supply. A factory run-in won't prevent this.
Could be wrong here but rule 5 reads to me like he's advising folks not to buy a flawed component to compensate for another flawed component, rather, fix the problem at the source (get rid of the component which caused the problem.)
All of his advise makes sense to me.
It is true that if your system plays in tune and in time* you will not notice that your room acoustics are less than perfect.
*For the pedants, faithfully reproducing music played in tune and in time.
The first sentence Richard - the scenario has a chap replacing an existing CDP with a "soft" sounding CDP without any troubleshooting to determine what's actually causing the system to sound bright or objectionable.
The net result may be less brightness but possibly a loss of musical information as well if the replacement CDP isn't as good as the original CDP. Better to locate and fix only the problem instead of possibly throwing out the baby with the bathwater using a shotgun approach. Just my opinion of course.
regards,
dave
OK. Since troubleshooting hadn't been explicitly mentioned, I assumed that it had been determined that it was, say, the CDP that was the problem. Of course, it would be irrational to replace an element in a system that had a fault without having good reason for thinking that that element was the cause. But buying a new "soft" sounding CD player, because the system sounds bright might actually be the solution, and if one chose wisely it might not lose musical information.
- Richard.
- Richard.
Arse-gravy.
