sergeauckland
From the Linn setup manual in the section of "Useless, Dangerous, and Foolish Modifications of the LP12":
"The use of record weights or clamps. ... Weights can destroy the main bearing, which is already working at a pressure of two and a half tons per square inch. Adding a two pound weight to the platter increases that pressure by twenty percent. Whatever improvement you may believe you hear will be immaterial as soon as the spindle drills through the thrust plate of the bearing"
"Other oils in the main bearing. As mentioned earlier, the bearing is subject to two and a half tons pressure per square inch. Linn oil is specifically formulated to eliminate the microscopic welds that can occur at that pressure. The long term use of any other oil can cause damage to the bearing"
Add that to YNWOAN's very comprehensive post above, and I'd say you'd want to be a little cautious before lobbing in any old oil...
Except that there's not 2 and a half tons of pressure at the sides, only at the thrust-plate. There, there may or may not be any oil between the bottom of the bearing shaft and the thrust plate. YNWOAN suggest not, Linn say their special oil isn't forced out by the pressure.
Frankly, in my own case, turntable oils are not something I obsess about.
S.
