Luca
Personally id have an ittok over a pu7.
+1
Of course linn used damping, what do you think the floppy arm board attachment was for?
Just a thought, as Orginlive found the Rega arm sounds best with the clamping nut just nipped up. Doing it up tightly kills the sound, makes it flatter and less dynamic. Given that Linnies like doing everything up so tight almost to the point of failure it is not inconceivable that a lot of Regas have been tried on Linns with less than favourable results. Just saying like.
I wonder how the Tenor stacks up against a Majik sub chassis?
Having just had the Karousel installed on a Cirkus subchassis, I'm interested in a cost-effective subchassis even if the table sounds amazing as it is.
Rega have always said the nut should not be over tightened. In fact if you did you could crack the plastic collar on the RB250.
To be fair, the stock RB250/300 could sound a bit too grey and dull on an already warm older LP12. It's not a disaster and they were still much better than the equivalently priced Basik arms but you needed the right cart etc to balance them out a bit. It's also harder to get the cable dressing right and that matters.
But a lot of it was just politics. Linn and their dealers did not want you to put a Rega arm on your deck as they knew how good they were.
I agree with what you say. It is amazing how many Linn myths are still out there
There's no difference between slack screws and a CLD interface, except one let's you perpetuate a lie...
The Majik sub-chassis extends under the arm fixing point so you are effectively bolting the arm directly to the sub-chassis with the arm board like a big washer in between them. I expect that to be good but different, possibly better? Depending on what you want. As you progress up the sub-chassis ladder they all stiffen up that joint.
The Majik is a box made of thin aluminium where as the stack is a machined thicker single piece. I'm inclined to think they are different rather than one being massively better than the other. I did consider the Majik but did not want to commit to a Linn arm.
