The Dali has a rear-facing port, I don't see that it can work well against the wall unless the port is puggled.
I was hoping not to have to downgrade the sound too much, tbh.Just for fun, buy a pair of Minimus 7 speakers, they hook straight onto the wall, and always make me smile. You can pick up a pair for 50 quid or less, and are great value for money.
Trust me, you will be surprised.I was hoping not to have to downgrade the sound too much, tbh.
We used to have a dining room with not much in it apart from a table and chairs and my LP12 on its equipment rack and the two speakers either side and angled towards a sofa at the other end of the room.
It was a solid brick built room and my Epos ES11 stuff sounded really good in it.
This house is brand new, cavity walls etc so it’s going to have to be something pretty special to work well against that kind of wall.
I asked on here in desperation really and I now think some slim floorstanders with a small footprint might be the only way to go.
As a long-term ES11 owner, I understand the challenge.It was a solid brick built room and my Epos ES11 stuff sounded really good in it.
They will have to go as close to ten wall as possible.As a long-term ES11 owner, I understand the challenge.
i may have missed it, but how far from the wall do you think you can place the floorstanders?
The Neat Iota Alphas mentioned above come to mind as do the Totem Arro.
I don't understand why there Aren’t more speakers designed specifically to go against the wall. For the most part one is limited to either no port or no rear port because they are least problematic rather than something specifically designed for that placement.They will have to go as close to ten wall as possible
My ES11s were about 2 feet away from the back wall and slightly toed in.I don't understand why there Aren’t more speakers designed specifically to go against the wall. For the most part one is limited to either no port or no rear port because they are least problematic rather than something specifically designed for that placement.
I did have my ES11s away from the wall a bit, but part of the reason I like my Kans and Saras is that they can go up against the wall, freeing floor space.
The Dali Oberon speakers look interesting. We are planning to go and look at some hifi shops to get more of an idea of what we want.If you're no looking at floostanders as well, Dali Oberon 5's are meant to be very placement friendly.
I had some Focal Aria 926's which were brilliant in a room that needed the bass projected forward, not that small and a bit over budget and slightly forward on the top end with bad recordings but apart from that incredible speakers for their cost .... I've seen some very recently on sale at £1200.
Most bookshelf speakers can go on a decent wall bracket if you're still that way inclined, I have a pair of Elac B5.2's as they're backed up against a window and the front firing bass port works really well in that situation, with your budget might be worth having a look at their Debut Reference DBR62's which get a lot of very positive comments.
