Hi Louballoo,
I'm in West Kent near Tonbridge.
Is it the current pot with 5 degrees of useful rotation? And what input(s) are you using?
Changing the pot for a different model will not change the level vs position as it's being used as potential divider. It follows a logarithmic law much like your hearing does. If it's far too loud then it sounds like your source level is far too high. Are you using 328 boards?
Mark.
Mark, As far as I know I have the stock set of boards except for a K board for phono and a set of jumpers where the second phono would normaly be. I'll have to open it up and check.
I'm in Alberta so sending my unit to the UK for an upgrade may not be practicable.
Thanks for your intrest,
Louballoo
