i_should_coco
I am weasel
Like ones for PCBs?
Yeah....
Like ones for PCBs?
Yeah....
Think it depends on era and where manufactured.
It's all the same metal. Octal valves have different metal used in their construction as the pins don't need to go through the glass.
Kovar is a special alloy which has the same coefficient of expansion as glass....
Servisol Super 10, I'm hooked on it..
Generally a fibreglass pencil does the trick.
A bit abrasive though and probably only a last resort if really bad.
The Silvo mentioned earlier was recommended by a friend in the trade and he was right
Not sure what chemicals are on the wadding but it does the trick on all kinds of electrical contacts. follow up with IPA as a final clean.
