Rega_Elex-R_owner
New Member
I am now having what seems to be the exact same problem with my two year old Rega Elex-R. Did Rega's service people find and solve your problem MasterTape ?
I hesitate sending it to service since I too "really dread the "nothing seems to be wrong with it" call" ....
As mentioned I did, and the imbalance is reversed, excluding room, speaker or hearing issues.
I'm not sure we'll get to the bottom of this to be honest. I'm left scratching my head and I have no reason to not believe the tech when he says he plugged it in and gave it a listen and found as little wrong with it this way as he did when measuring test tones to be within a tenth of a milivolt at the terminals.
But in my setup it exhibits this behavior, and the three other amps I've had in this exact setup all were fine. If it doesn't at his place I can only assume there is some very mysterious interplay issue with my source and the Elex, weird as that would be given that anything else I've plugged in has worked before and since.
It's not extreme, think of it as a 10-15% shift to the right for the centre image. But enough for me to not be able to ignore it and enjoy the music since the sensation is one of my left ear not working properly.
I have also had two different dacs in the short time I've had the Elex, same issue with both. So that leaves the little Digione streamer but I don't see how it can be at fault when there are no issues with other downstream combinations. Same thing with the cables, I've tried numerous to no avail despite not seeing how they can be at fault when working just fine with other amps.
I frankly don't have any ideas. All I can do is assure you guys I'm not hearing things since the L/R speaker switch and an amp switch demonstrates the issue to be with the Elex's interaction with my setup.
