MasterTape
Hi guys,
Thought I'd check to see if anyone has had any luck sorting this kind of thing.
I bought an Elex-R used and thought it sounded great but soon felt something curious with its sound. I later identified this sensation to stem from the L channel being slightly weaker in volume, most noticably in having a weaker treble shifting voices to the R in the mix.
I first worried about the speakers and possibly my left ear but a few days later I pop an old amp in there - same cabling, same everything - and it's bang on center again. I plug the Elex back in, it's shifted to the right. I switch speakers on the amp side and it shifts left. It's the amp, no question about it.
I have no measuring equipment, all I did was check the speaker outputs and gave them a cleaning to no effect.
Does this snippet from Regas description of the amp have any bearing on where the problem might be?
"The Elex-R uses a combined feedback and passive volume control, where the feedback and input levels are varied to set the required volume level. The level and tracking between the two channels is set by the close tolerance parts in the pre-amplifier circuit and less by the actual potentiometer itself, thus keeping the mismatch of channels due to volume control tracking irregularities to a minimum."
Thanks.
Thanks.
