irb
Well, if these gain figures are correct then yes the Quad II Classic should be fine, as the Sugden is acceptably quiet through the Nagra + Falcon LS3/5a combo, whereas the 303 is not (unless I use a 34 pre). However, I’ve been quoted 1.4 Volts today from the head of Quad service dept, so I’m none the wiser really...although it is perhaps encouraging that JA has actually measured the amp and come up with a figure that would be about right.
Well, if it's 1.4 V input for 15 watt, the gain is down about 18 dB. Even better from the noise point of view.
