Nagraboy
Ausculta fili
I’m thinking about getting a pair of these to use between my Nagra PL-P preamp and Falcon LS3/5a speakers.
I’ve noticed that input sensitivity seems to affect background noise in the system, eg. the Quad 303 with 500mV leads to a bit of noise through my speakers unless used with a Quad 33/34 preamp, whereas my Sugden A21ap is much quieter via the Nagra pre than the 303 is.
Unfortunately, when looking for the input sensitivity spec for the Quad II Classics it seems there are multiple different figures quoted. Some dealers websites have quoted: 570mV, 775mV and 1.4V. Quad’s own website says it’s 775mV, the 2005 Stereophile review says 570mV. Quad’s service department quotes 1.4V for 13 Watts, even though everywhere else says the figure is for 15 Watts.
Thinking about it, I can’t see that the new amp would have a higher sensitivity than the original (ie 1.4V) unless they’d changed the circuit quite a bit, although I’m no expert. I know they now use a GZ34 rectifier instead of the original GZ32 now but I don’t know what else has changed.
If it really is 1.4 Volts for full output, will that work properly with my Nagra valve pre?
