More specifically (I had the problem along with several others here), the cure for the Qobuz app on LMS was to get it to either:May not be relevant to your set-up but I had a problem with LMS and Qobuz where it would play part of a track then jump to the next, solved by increasing the buffer size in the server. I think your issue is more likely to be within the streamer than the control app.
I have one of those and, occasionally, that problem with Qobuz . It’s clearly a bandwidth issue as it only happens with high res streaming - at least so that’s the case to date.Phil,
If you're not aware, Mconnect or whatever app, doesn't stream anything itself. It does not stream music to your BC. The app merely acts as a remote control (as it were) for the streaming board in the BC. That board does the actual connecting to the Qobuz servers and sreaming the content.. BC don't make the board; I believe it's a Converse Digital product.
This type of issue is usually a problem with your network. Qobuz HiRes in particular can be problematic. Use decent ethernet cables and make sure they're all well seated. Buffer size is a function of the streaming board; you can't do anything about that. If you know someone local with a network bridge, or streamer with a digital out, perhaps they could come around and connect to your BC? If that works with no problem, then you know it's a limitation of the BC board.
A further thought here is the Virgin router, especially if it;s a Hub5. Many people using that report streaming problems.
I've experienced the same behaviour with a bluesound node and Qobuz although it's totally random and infrequent to be considered a problem.This happens to me on rare occasions listening to Qobuz through Bluesound Node 2i, and it happened a lot more when I used a PC. So I think the problem might be peculiar to Qobuz. Odd thing is, you can skip to the next track just fine. Then if you go back to the problem track, it decides to play. The frequency of these pauses is much less than it used to be, but very annoying when it happens.
I’d ping Bel Canto. I think your amp has a CMD4140 streaming board, it might be possible to increase the buffer size - that might help things, email tech and ask if there’s a buffer size setting.ok now this is very very odd
if i play david wright dark matter track [ first track]
Continuum - AD Music Shop
Available as a replicated CD and 16bit mp3 and flac. Check out our CD plus free 16bit mp3 or flac option. Check out our FAQ page for more information.www.admusicshop.com
using the sonos playing qobuz into my eix . it will play the 11 min track in 11 mins with no stops
using the mcontrol HD app playing qobuz on same track it plays the same 11min track in 3 mins !!! checked it twice
whats that about ?
Pity, worth asking thoughflip me emailed BC on a saturday night and they replied in about 5 mins or less!!! wow thats fast !!!
dont think there are any buffer options though
