suzywong
Wot, no electrons?
Electronic engineers are not unbiased, they surely are biased.
Only if we grab hold of the live rail!
An engineer does not make that assumption. Every engineer designs for the ranges of inputs a design will experience. That's normal procedure and it includes mains power.
There are, for example, test conditions in published IEC 60000-series (IIRC) standards, set out by engineers for reference by other engineers. These provide mains supply ranges and other deviations from perfection for designers to test their designs against, to check that they cope with the sort of imperfections expected on mains supplies. That does not mean all engineers are good and do this, of course. And it is possible for mains supplies to occasionally go further away from perfect than expected.
From a system architecture PoV the best place to cope with mains imperfections is right there in the basic power supply. If anything can be done externally it can be done in the best place too.
The more I pay for a bit of kit the less sensitive I expect it to be to unwanted external influence. The world of high-end audio seems to work differently. But I do know others see the hobby in a way I don't.
We are talking about power cables here ie a kettle lead, not ring mains, conditioners or anything else.Why is it assumed that every one has the same electrical supply. Why do you assume that people do not hear improvements. Same electrical supply but why would a loaded ring main sound the same as a dedicated ring or radial circuit. Electronic engineers are not unbiased, they surely are biased.
I have had enjoyable electrical supplies without problems and audio disaster in my current home where the components have adjusted voltage.... not at all good ...however using a regenerator makes an incredible difference. I use interconnects using 100% silver foil according to maker with superb results as opposed to the resident electronics genius with who sticks with the wire to get you going.
Fuses have nothing to do with sound.....what absolute cobblers that is!
I have highish end kit with a fantastic sound and if i abided by the electronic engineers I would not have achieved such results.
Electrical engineers have a far greater knowledge than me but superior sound can be achieved beyond a book.
Nothing else matters.
Well done for fessing up, there are others on the forum that have been down the same route.My experience. From the early days in my HiFi journey some 35 years ago I was a cable believer. Every dealer used expensive cable and recommended at every opportunity, some cable manufacturers had demo kits you could take home (Audioquest was one kit I took home) and the HiFi magazines gave away awards and 5 stars to hi end cables.
I spent a small fortune on all manner of cables and always thought I heard a difference.
I had some Chord top of the line speaker cables that were just north of £2000. They replaced some Nordost Red Dawn which I also thought better than the ones they replaced. I used for a couple of years but had started to pay attention to the science of cables.
One particular article made me determined to prove to myself the expensive cables were worth it. I purchased some fairly cheap copper cable from eBay and banana plugs. Total cost was circa £50 max and easy to make in an hour or so.
I swapped and was sure I could hear a drop in SQ, swapped back and was sure it sounded better. I spent a little while swapping back and forth and then got my (also HiFi addicted) son to swap between the two cables without me having a clue as to which ones he used. Some times he would swap, others he would not but tell me he had.
Result - no discernible difference.
After this I did the same with my expensive mains cables, same result.
My system was north of £20,000 so not as someone commented ‘too cheap to highlight the differences’ and at times quite a bit more.
I am so glad I escaped the expensive cable merry go round as there is always another version/upgrade/new brand etc which gets in the way of enjoying your music.
My advice, focus on the fundamentals, system synergy, good support, well made (not expensive) interconnects and speaker cables, speakers that work in your room and appropriate time invested into room set up and treatment.
Tuppence worth from me…
