Big Tabs
looking backwards, going forwards
With that amount of regular cleaning, Tabs, I'm surprised you haven't invested in a vacuum RCM. The Knosti is clearly good and superb v.f.m., but a vac. RCM offers far more cleaning techniques and ultimate efficiency. As the Knosti cleans both sides simultaneously, I'm not sure if the vac. machine would be quicker unless it's a two sider one. Having said that, the simple effect of the vacuum is to shorten the drying time by quite a factor, so it must be quicker as well as its other attributes.
Depending on the state of the vinyl, I can clean a record and have it drying in about 3 mins a disc.
I wipe the first layer of dust off with a very damp cloth before using the Knotsi, as when cleaning 30-60 records there is no sense in adding visible static attracted dust to the solution bath.
I change the solution after about 60 records, depending on the state of them - mouldy records get washed under a tap before using the Knotsi - again there is no need to contaminate the solution if I have a big batch to clean.
I would buy a vac or sonic machine if I thought I needed one - but I get great results without. The physical aspect of the cleaning activity is good physiotherapy for my hands/wrists as my hands/wrists are damaged and need physio to keep the limited movement as good as possible.
