silverdarter
Active Member
I recently upgraded my LP12 and whilst it brought some improvements, it also went downhill in other areas. I am a musician and producer, but it has only been in the last 6 months that I've had a home system that really brought recorded music to life. So I'm experienced with audio (studio and live), but an audiophile-in-training as it were! Currently experimenting with setups / different gear. So any advice on the LP12 changes would be extremely useful. I am taking it back to the specialist on Thursday for a listening session to show them the issues. But perhaps you can spot something in the chain that might be the culprit?
I use a Naim Unitilite, Musical Fidelity V90-LPS, Nexera phono cables, QED Silver Anniversary XT and a pair of original Rogers LS3/5A (15 Ohm).
Turntable Previous Spec: 1984 LP12 - Basik LV-V arm, Adikt cartridge (second version - new old stock) new Valhalla, everything else original.
Turntable Updated Spec: I had a secondhand Cirkus bearing installed with a secondhand pre-Majik subchassis. I also put the Adikt onto an Ittok LVIII (earlier version) which came in superb physical condition from HiFi Hangar.
Why I did it: I had previously upgraded from a Denon DP-15F with OM 10 and found that the LP12 had a really beautiful sound and opened things up a lot, but thought it a bit thin on the lower end, and noted that for orchestral music, some of the depth that I was getting with the Denon (for example - the ability to truly visualise the orchestra with eyes closed) had vanished. I did also notice some of the 'grit' had gone. For example the epic guitar solo on Supertramp's 'Goodbye Stranger' lost its edge. The mids and top end in general were astonishing however, and everything was working really well with the Rogers to make non-musician friends squeak with excitement or cry, depending on the track!
Result of Upgrades: The lower end is dramatically improved, beautifully clean, well-rounded and warm. Drums sound incredible and bass is clear and joyful. But the mids have been destroyed and the 'magic' previously present has been lost. It feels like something is now fighting the very strength of the LS3/5A. At low levels it's ok, but at volume the mids quickly disintegrate and become harsh. Vocals become sibilant, lead guitars screech and make me wince - it is no longer a pleasure listening to music unfortunately. Whereas (despite a few areas I wanted improvement in), it was always a complete joy previously. On top of this, orchestral music now definitely sounds more synthetic, sterilised and muted. Driving it harder doesn't open it out. Magic is a funny word to use, but it is appropriate as things really sang before. There was a considerable amount of emotion that came across, but this has been mostly deleted by these harsh mids / whatever is wrong.
I have bought a Linn Karma cartridge as I heard it has a warm sound - I'm wondering if this will help, but feel like I might be trying to patch things up, rather than root out the culprit. Ultimately I'd like to get a valve amplifier, perhaps a Rogers E20, for more warmth and to ensure harmony with the LS3/5A.
Anyway, I am pretty confused and slightly panicked, as surely an Ittok is a great upgrade over a Basik LV-V. Likewise with the Cirkus etc. But I know that 'better' or 'more expensive' doesn't always translate to an improvement, and any change can unsettle the balance of a system. One thought I have had is to revert some of the changes and do them again, one by one. Rather like Sherlock Holmes, cracking the case through the process of elimination.
I would really welcome any advice please. Upto and including 'You fool! How on earth could you contemplate pairing X with Y, change that for Z and you should get a better result.'
