Standard LP12 black oil breaks down over time, separates out, I don't know what the heck it does but it goes bad! I used to aim to change that stuff once a year-ish. A couple of other LP12 oils I tried also separated, you could see it happen in the bottle.
Audio Origami oil doesn't seem to. I used that in my LP12 laterly, as it sounds better, and it's so cheap that changing it is no big deal.
Rega use a heavier, sticky gear oil and they don't recommend changing it. The Lengo uses grease in a porous brass bushing but whatever the bearing is made of it's going to wear and you've then got bits of bearing liner circulating in your lubricant!
On the lenco I'd check the brass liner for wear. New ones are cheap and easy to fit, just buy a few and use the one that gives the best fit. If you fit a rubber boot over the bearing you can run oil in the Lenco, which to my ears sounds better.
The Spacedeck I know nothing about but I wouldn't run any turntable for years without servicing the bearing. You don't know what's happening in there. The oil could by fine or it could be tar! It could be low causing wear, the bearing could be worn and need replacing. I'd want to get in there now and again just to check on the health of the thing. Why not?
