Chops54
Some interesting thoughts there Clive. What about a pair of ring magnets under the platter, not to float it but just to take some weight off the ball bearing. Is it the Platine that does that? Fwiw my own turntable uses a Clearaudio bearing with a small diameter shaft and ball bearing something along the lines of the Rega but inverted so I use a dob of grease on the ball bearing. The aluminium/acrylic platter weighs around 8kg and it's showing no signs of wear after four years of constant use.
If I'm properly back on my feet in time I'll come to Scalford and have a look at your deck.
