Jim,
Yes, the USB isolator should solve your issue
Thank you all. I will place an order today for the isolator. Is there any reason that this should pop up with no changes to the system after 2 years or is this just random?
Thanks again,
Jim
By the way...The Mojo Audio Mac Mini has a bunch of mods to it below that are either voodoo or help with filtering, but it has worked beautifully up to a few weeks ago.
Internal Filter Module features:
LCLCLCCCCC spread spectrum filtering for expanded bandwidth
Removes EMI, RFI, digital, and clocking noise above 100MHz
High-performance hardwired or convenient removable DC power cable
Fully shielded inductors on both the positive and ground
Anti-resonant thermally transparent internal mounting system
No unnecessary dielectric covering to add noise and hold heat (shrink tubing)
Comparable to our competitors "Level 3" Internal Power Filter
We use only the highest-quality parts:
Organic polymer capacitors with ERS as low as 7mOhms
Metallized film or foil and film bypass capacitors
IXYS ultrafast soft recovery Hexfred diode bridge
Vishay 5ppm 1% resistors and 15ppm film trim pots
Furutech rhodium-plated IEC AC power inlet
Neutrik silver-plated XLR DC power outlet
Heavy gauge all-aluminum chassis
All non-magnetic stainless steel hardware
Durable high-temp powder coated inside and out
Your choice of black or clear anodized face plate
Triad precision wound 160VA toroidal transformer
EAR antiresonant feet
