Yes, possibly
Not necessarily just the mains (see below)
Lower powered
- the argument
may be that any noise artefacts the psu is putting out are at a lower absolute level because the power demands are at a lower level
However the voltages being created for the supplies are the same levels whatever the power, so it's a big maybe
Only some proper emc measurements would give the answer and it will be component dependent
No WiFi
- WiFi is inherently a source of RF noise - that's what wifi is: an rf signal
So if the nearby equipment is sensitive to external RF noise, it's a good idea to remove a local source
Only use wifi if you need it. You could always try running the PC wired vs. wireless (disable the wireless adapter within the OS - or better still turn off or remove the hardware) and see if you can hear a difference
Your mileage will vary
Low emi and rfi
- yes that's the underlying objective
whether a board which proclaims low emi and rfi is actually any better than a 'standard' mini itx board is open to question - they all have to (should) meet emc directives
again would require proper emc measurement
Linear PSU
There are a lot of misconceptions around about linear psus vs switch mode psus - the devil is in the detail
There is no doubt that the switching nature of a switch mode supply has the higher likelihood to generate emi and noise on the output or back into the mains, but it all depends on how (well) it's been implemented.
Hypex swear by the low levels of emi produced by their class D amps (and their SMPSs) see
http://www.hypex.nl/docs/appnotes/EMI_appnote.pdf. If implemented properly there should be no inherent reason why a linear supply will be better than an SMPS
However...
a 'standard' mini-itx pc won't necessarily be any worse than one implemented with the above measures
Overall my recommended two prime measures, whatever the PC, would be
- usb isloation
- mains filter between PC & hifi
