JohnW
pfm member
I 've got a big fablab close to my house so if you can provide with the plans i can manage to make my own support either in acrylic or in plywood using their laser printer
We can send you the DXF file of the PCB's arranged with there mounting holes.
You talk about adding "buttons" i think that you mean physical buttons to interact with software. When you send me the DEVDAC could you provide me with a hardware description of the "buttons" interface ?
No, I mean "software buttons" in the streamer UI that communicate to the DAC to select the digital filters / DAC inputs. We can work with your students to add an APi between the CM3 (streamer) and the DAC board to communicate the relevant settings. We have various "hardware" communications paths between the CM3 to our audio system to facilitate this.
Moreover is it possible to have 64Gb eMMC instead of 4 fot the streamer ?
On an earlier design we tried mounting the 64GB eMMC IC's twice without success... each memory IC cost about US$60 so it got expensive.
I've 2 more IC's I can try but its expensive when we fail!!! We are not sure where the issue is - poor BGA alignment on the PCB, PCB Design error (with the larger eMMC devices as we have success with 16GB eMMC devices)...
If your prepared to take the risk we can try again, I've a purchased a BGA rework station but I've not installed it yet, or have any working experience with it (yet )....
