errrm 18thTotally OT (sorry), but: Which Saturday - 11 0r 18?
John,
Thanks for the update that is great news!
Guess I will take a look at MoOde and try it on a RPI while waiting for the DevDac and streamer.
Really looking forward to hearing the DevDac and streamer combination![]()
Any Moode users note the next version 4 will not be a simple Image to put on a card, setup and run it. It will require running some Linux coding to create the img. Get you hands dirty and check out, enhance your IT skills.
WRT to the streamer software there are two options offered at the moment:-
Volumio and MoOde - we can ship with your preferred option (you can try both options by re-flashing the onboard eMMC)
John,
That’s good news. Will either of these be necessary if Roon is used?
John,
Is this a potential problem? I'm guessing you already have it covered.
Rune
Hluga
Stephen Grenfell
Jadidih101
I've emailed you with payment request for the DevDAC (and streamer PCB where required).
We will ship within two weeks - Jadidih, yours will be first to ship...
These first DevDAC systems are really "developmental" but I believe you will see a rapid advancement in there "fearture set". Hardware's "nice" we "just" need to start the ball rolling on the software...
Rune
Hluga
Stephen Grenfell
Jadidih101
John,Rune
Hluga
Stephen Grenfell
Jadidih101
Thanks John. Payment for DevDAC and MDAC2 streamer made. Looking forward to receiving them.
Sorry to hear about Volumio but I am sure we can get the ball rolling with MoOde and perhaps revisit Volumio more in future.
Don't sweat the software too much. Just, please get the hardware out and we can work on fine tuning the software over a longer period, which was the expected situation anyway.
Which was the expected situation anyway.
Thanks!I've just sent you a PM![]()
I’ll take the Volumino build for the streamer since it comes with Roon Bridge pre-installed.
My interest is in Roon, as this is the player I use for all my music (few thousand CDs on a NAS) and Tidal. But I will also play with Volumio and try the moOde build.
The mini steamer chassis fits the DevDac + steamer board right ?, what does it cost ?.
Thanks!
I have made the payment.
I 've got a big fablab close to my house so if you can provide with the plans i can manage to make my own support either in acrylic or in plywood using their laser printerOK, noted, we will ship your unit with standard Volumio installed.
No, the Ministreamer is a standalone streamer in its own chassis - its 120mm Deep x 108mm Wide and 26mm High.
We are considering offering a laser cut Acrylic sheet with the 2 pcb's mounted :-
https://www.elecrow.com/5pcs-acrylic-laser-cutting-service.html
We would need 300mm X 300mm 5mm clear acrylic sheets - they are rather expensive, but would offer a stable & secure platform for the PCB's (and some physical protection to the bare boards, but don't slide the acrylic on say the carpet as this would Static generated could damage the streamer).
