Hi John
Can you kindly advise on this. My system is a Michell Orbe, SME V arm, Benz Wood cartridge fed into an A.N.T. Audio Kora 3T pre-amp which I assume has a fixed RIAA equalization.
Quote:
Originally Posted by sprint
Thanks for the reply. What is the implication of not being able to use the FDAC Digital RIAA mode?
The FDAC phone pre will allow the user to choose between analogue and digital RIAA equalization. Maybe the digital version will be user adjustable for some tweaking...
Most likely your external phono pre won't allow you to turn off it's analogue RIAA equalization.
What inputs will the ADC have as I believe I read that it will only be balanced? Will there be a RCA input, most phono cables use male RCA connectors?
Two XLR Inputs, no RCA. You can build a simple adapter cable as explained by John: http://www.pinkfishmedia.net/forum/s...69#post2762169
Why is there apparently only balanced inputs into the ADC and no RCA?
