Hi John.
I need you to clear some space in your PM-box so I can send you a message. Thanks!
Kind regards,
Peter
Hi John.
Kind regards,
Peter
They do need their top end to be less head shattering tho![]()
John as previously discussed , I would also be interested in a pair of modded 8200mb to tie me over and to use in a surround setup afterwards .... But only if there is time between your busy schedule![]()
Hi John,
Do you think the modded 8200MBs are able to handle my ESL ElectroMotion? Unfortunately the Super MPWR didn't, so I had to go back to my studio amp... Do you believe the monos could be a good match for my EMs?
I'd be interested in a pair of the 8200MB's John.
Phil
+1 on that, Peter. I was just thinking the same thing. Thanks, John.
OK - I feel really bad about the MPWR - please don't tell me I sold you the MPWR when you already had the ESL ElectroMotions?
I'll keep a pair reserved for you - I need to complete the DETOX and FDAC Analogue PCB first (by Mid October) then I'll work on the 8200MB's - if I can squeeze in my "crazy" idea then they will be PERFECT for your ESL's (as the VFET amps are silly money!)
This sounds very promising, thank youAnd no, don't worry - at the time, I bought your S-MPWR, I owned a pair of Totem Arros. I really loved that combo!!
But then I gave the ElectroMotions a trial and even though they do not have the perfectly matching amp/s yet, I'm very happy with how they perform!
Kind regards
Malyq
I would also be interested in a pair of 8200MB if you have some left.
There was a thread on here where some problems with a batch of MB with sub par transistors, might be worth investigating?
Phil,
OK, a pair reserved for you, you should consider having the Vishay Bulk foils fitted(Bulk foils fitted "at cost")...
As I mentioned in earlier Emails, I'll play with the amps once I've completed DETOX and FDAC analogue board - I'd like to use a Miniature tube in the front end circuit but need to figure how to provide the heater supply rail.
With the circuit corrections, Tube front end (if possible), remove the cheap Opamp + True balanced input stage then they will be more then decentAtleast something I can use before the VFETs come online...
I need to turn these units back into cash as I will soon need to pay the tooling costs for the VFET chassis and prototypes etc.
Yes, sorry the PFM inbox only has 50 spaces, and it fills very quickly...
Renata's just emailing you my EMail address - but these 8200MB's are only 230V units![]()
