iansr
Like a plywood shelf with a support block to the rear?
I know someone who can do that![]()
Worth a couple of pints I reckon
150-200mm sheilded USB cable to manufacture then..![]()
...with separate shielded pairs for +5V/GND and D+/D- OR, or in my case, no +5V.
Someone on Computer Audiophile
http://www.computeraudiophile.com/f...egen-listening-impressions-24078/index67.html
just posted this tweek...
https://www.sbooster.com/sbooster-tweaks/sbooster-vbus-isolator
I'm not advocating a solid USB link as the Detox with its soild RF screening will be heavy, I cannot recommend "hanging" it off the rear of a DAC's USB socket.
I "believe" the thinking of the ReGen was to design to be as small and a light as possible so it could be safely hung of the rear a DAC - but to achieve this the designers had no choice but to limit the designs potential (limited PSU filtering, not the greatest clock, no RF filtering etc).
You have to weigh the Pros and Cons of these limitation - while a direct connection is "nice" IMO better RF & PSU filtering is more important.
Good point I hate USB B.
What exactly is the point of it.
I think that it's a way to avoid connecting two USB hosts.
Let's not do that, using USB B on the device side is a good convention and it allows for easy "detox" bypass if necessary (PC A -> detox B -- detox A -> DAC) or easy plug-in into existing setups (where the DAC has type B).John,
Wouldn't it be possible to fit the Detox with USB A plug and USB A socket (as it happens in the Jitter Bug) so that in some cases only one USB cable is needed?
Yes, correcthas to be "A" and "B" Style....
I see no reason for necessarily being A and B as electrically they are exactly the same...
I would definitely prefer A and A (like the jitter bug) in my case.
Yes, but its strictly frowned upon by the USB standards committee. As a designer is good not to upset such committees... Some battles are worth fighting others not...
"Unlike other data cables (e.g. Ethernet, HDMI), each end of a USB cable uses a different kind of connector; a Type-A or a Type-B. This kind of design was chosen to prevent electrical overloads and damaged equipment, as only the Type-A socket provides power. There are cables with Type-A connectors on both ends, but they should be used carefully.[4] Therefore, in general, each of the different "sizes" requires four different connectors; USB cables have the Type-A and Type-B plugs, and the corresponding receptacles are on the computer or electronic device. In common practice, the Type-A connector is usually the full size, and the Type-B side can vary as needed."
OK. I understand but I think that it would be a better solution for many who would use it carefully.![]()
Out of interest what's wrong with the type "B" connector?
Interesting list, however
RAVENNA is actually not a protocol, it's again (like DLNA) a set of guidelines, it uses RTSP/RTP for the stream itself. It really looks like a copy of DLNA minus a lot of the video stuff.As I already mentioned Swiss co Merging Technology make professional recording studio gear and a new DAC based on Ethernet:
This uses the RAVENNA protocol
UPnP is a generic autoconfiguration / discovery "protocol" (actually again a set of protocols), not really tied to audio streaming in any way. It can be used for anything like printer discovery on a network, to automatically forwarding a port on your router (for computer games), to ie. discovery according to DLNA. It's "just" a convenience protocol, all the stuff it does can be done manually.This doesn't mention UPnP which I guess is mostly used in domestic systems.
https://en.wikipedia.org/wiki/Universal_Plug_and_Play
- Richard.
I use one of these - http://rover.ebay.com/rover/1/711-5...0001&campid=5338728743&icep_item=321735398471 / http://rover.ebay.com/rover/1/711-5...0001&campid=5338728743&icep_item=321735401182.Having to use two USB cables.
If A to A I would connect the Detox directly to my PC.![]()
Can we postpone the A/B connector discussion until we know the Detox's dimensions?
Direct connection to Host or DAC might not be possible if it's to big.
