misterdog
Not the canine kind
Not sure about the time limit myself...misterdog I guess will know...
I'm afraid you overestimate my powers, I only know from having been timed out myself.
I could have a guess though
I could have a guess though![]()
You know the rules: no subjective impressions allowed.![]()
You've got my attention and 50 GBP!
Will be interesting to see what the eye patterns look like with DETOX!
Audio over Ethernet
https://en.wikipedia.org/wiki/Audio_over_Ethernet
I last searched for this a year so ago. I only did a quick search now to find this link. Please feel free to continue the research.
Jirij, you'll interpret it far better than me anyway (thanks)
IIRC the protocols are specific to an audio application and there are 2 common (commercial?) protocols, so not a "standard" part of a PC configuration or general purpose network.
So it's quite right that John is concentrating on DAC design above interface protocols, and concentrating on optimising the interfaces that are already common.
Possibly the bespoke interface which will connect fdacs together (have I remembered this correctly?) will allow alternative external interface modules to be implemented in the future? but that isn't part of the current design objectives to create a statement design based around "conventional" interfaces
No apologies if I've remembered or interpreted any of this incorrectly.
Welcome to the Detox projectThank you for your support.
It will be an interesting challenge to measure the LF noise directly on the USB data stream - hopefully once the new test system arrives (its still not been shipped) it will make the task easier.... lets see
JohnW do you think BigDog will benefit from a Detox given he already has galvanic isolation and is about to remove USB +5V?
Re #5: I am using an Adnaco-S3B: USB 3.0/2.0/1.x Over Fiber Optic Extension System to provide galvanic isolation between my PC music server and DAC. However, since my DAC is self-powered and does not need to see the +5V, I defeat the +5V normally supplied by the Adnaco receiver to a DAC.
I am not receiving email notifications of posts to the forum as I selected in the Forum Tools for this thread.
Since I am on the edge of my seat with anticipation of each and every reply ;-),
I sign on frequently to see what's new.
Audio over Ethernet
Hope you are feeling better, John.
You mentioned clocklock of the DETOX with the MDAC / FDAC but not with other brand DACs.
Would there be any downside with the presence of the clock with other DACs?
Got to thinking about how the DETOX will dock with my DAC. I think I saw in an earlier post that you were planning to use a rigid USB adapter to avoid using a cable.
What are you expecting the dimensions of the DETOX case to be, particularly the side where the adapter will go?
Want to see how this might work since like most DACs, mine is a bit congested with other jacks close to the USB2.0.
Follow up to original post: Signed in this morning and found numerous posts for which I did not receive email notification.
Typically on forums when you are already subscribed to a thread and click on FORUM TOOLS, it will have an option to UNSUBSCRIBE. I do not see this message but do see SUBSCRIBE TO THIS FORUM. When I select this option, it asks for selection of notification, which in my case is INSTANT EMAIL NOTIFICATION but this is not happening.
Thanks.
I'm not advocating a solid USB link as the Detox with its soild RF screening will be heavy, I cannot recommend "hanging" it off the rear of a DAC's USB socket.
I "believe" the thinking of the ReGen was to design to be as small and a light as possible so it could be safely hung of the rear a DAC - but to achieve this the designers had no choice but to limit the designs potential (limited PSU filtering, not the greatest clock, no RF filtering etc).
You have to weigh the Pros and Cons of these limitation - while a direct connection is "nice" IMO better RF & PSU filtering is more important.
This does not surprise me as I believe that the notification service can be quite slow, my experience from other forums is that its not "instant"..... its more for people in a slower lanewho are interested in "daily" updates then minute by minute news...
Thanks.
Thanks, back working
There is no "downside" to having the Clock Lock circuit in the Detox, the switch removes the Clock Lock circuit from the internal signal path when not required.
Subject to the relative positions of the sockets you could always support the Detox so that it was at just the right height for a rigid connector.
150-200mm sheilded USB cable to manufacture then..![]()
