I've had the no sound thing where the meters bounce around but nothing else happens. Turning it off and on again usually fixes. I regressed to an earlier flash too and since then not experienced it since, and I think I noticed an SQ improvement. Was a while ago, so no bold claims.
Same here, simple source up then down again fixes it, no need to power cycle.
My understanding of the HQ PSU was that it would only go ahead if it was shown to provide improved SQ over the std PSU? Is that still the case or has one been built and shown to provide improved SQ?
Should the HQ PSU not provide significant improvement in SQ then would there be anything to be gained by using the FWC?
What would be the position for those who go the original DIY route and fit the MDAC2 PCB into their existing MDAC's, how would they be able to add the HQ PSU if it was proved to provide improved SQ? Would they then have to purchase a FWC as well?
Thanks John for taking the time to reply considering how busy you are. I will try to find a local dealer who can let me test with a working AC adapter.
Cheers!
MDAC 2 might get some competition. I am thinking of buying MSB Analog Dac with Diamond Power Base.
Tomorrow I cross the board into China to meet the CNC vendor - I worry about there set-up, I suspect they are just a trader rather then the direct factory contact. If this proves to be correct, then I have other options but I'd rather not need to divert my attention to much.
I'm not looking forward to the trip into China, I don't have anyone local to fall back on if something happens - I'm on my own on this one! Maybe I've just got used to the security and safety of may lab in Czech - China is a rather drastic contrast.
It looks likes it will be called the Fusion DAC, as its a Fusion of miniDSP and my DAC / Analogue design skills and IP )
Fusion DAC
