JohnW
pfm member
The compatibility chart in the item description lists the MDAC as 16v x 3. Isn't 16v too high for the MDAC?
Thats 16Vdc so its fine
Matt,
The PSU you linked too is just a higher quality AC transformer in a case - this guy looks far more promising:-
http://rover.ebay.com/rover/1/710-5...0001&campid=5338728743&icep_item=281448219198
Johnw,
I've got an opportunity to go to plzen for a conference close to June 8. Is it close to where you live ? If so i can manage to have time to visit your lab
If not i have to wait until my venue (end of august) to pick up vfets and mdac2.
best regards,
Matt,
Last week I had a play around with the Creek Evo 50 CD player compared to my Rega Apollo R/MDAC L3 Toy combination.
I understand that Dominik had a part to play in the development of this player. I also note that it uses two Wolfson DAC chips and has an op amp output stage.
It bettered the Rega/MDAC combination for dynamics, bass drive, Timing and tunefulness.
The Rega/MDAC were slightly ahead on texture in the midrange.
On balance the Creek was the overall winner.
Swapping the Mark Grant Oyaide digital interconnect for one by Audio Mica narrowed the gap in terms of timing and bass drive but the Creek was still ahead.
We ran out of time so I did not get the chance to try the following:
● Using the Creek as transport with the MDAC L3 Toy as a DAC.
● Allowing the MDAC to warm up for more than a couple of hours.
My suspicions are the weak link is the Rega or the data transfer between the devices. Would clock locking likely fix this?
I wanted to stay with half-width cases as they can be accommodated on one shelf but I accept that MDAC2 will eventually be a full-width design.
The Creek seems incredibly well-made and the slot - loading mechanism is great.
Despite the Rega's relative shortcomings it has bettered most PC/streamer alternatives that I have tried so far with the exception of some of the kit brought round by Mark/Item including the Aurender X10. As a main digital source I intend to stick with disc spinners.
I welcome thoughts, particularly from John himself.
Please do not contest my findings thus far because this will simply generate heat and no light. I'm looking for causes and solutions to meet MY needs.
Your mileage may differ. Obvs!
Similar mileage here.
http://www.thehifistore.co.nz/includes/pdfs/review-27.pdf
The Creek player is the one that I could live with instead of my UnitiServe feeding the Resonessence Mirus DAC via S/PDIF. In fact I am living with it
Jan
VAT is 20% in the UK and duty on hi fi gear is usually a few percent, so you end up paying up to about 25% of the cost inc shipping.
Has anyone tried the Q Dac?
Jan
Jan,
As usual the review is full of errors - for starters the CD servo is NOT a DVD IDE drive but a CD slot loader with custom designed servo board whose Mechanism we originally sourced for the Lakewest CD transport project and Dominik had great fun designing the servo PCB - likewise "Custom control software written by Creek" is fictional. The idea was to make the servo solution available for other designs, and we designed it into Creeks player.
But they are VERY nice units![]()
John
Apologies, I've tried searching through the threads but can't readily find the answer:
What ADC chip are you planning on using for the L3?
Hi JohnW,
On the Tag dvd32r player you have a synclink connection to allow the receiver to control the clock on the player. Can this somehow be controlled by the mdac? It is connected via a coaxial cable.
Always have read that this unit is very low jitter and excellent cd transport, especially when connected with this cable to the tag av. Wonder what's the performance like compared with today cd players.
Subjectively they are indeed, especially at the price point.
Doesn't the Creek also have an opamp analogue stage, though?
