JohnW
pfm member
Will the XLR connection of the mdac2 be superior to the RCA or is there also a benefit of the new output stage for the RCA?
With the MDAC1, its Balanced output is compromised for the sake of the Single ended RCA output - and yet single-ended signalling (relying on an unbalanced ground return) is a floored concept, so performance has been compromised to support a poor "standard"
the MDAC2 designs optimises its performance of the balanced, yet significant effort has been made to insure the RCA Single Ended output has not much to be ashamed off.
With the balanced output you have in effect a simpler analogue path.
Would you recommend a XLR-RCA converter?
I cannot see any external Balanced to SE solution being better then the MDAC2's internal design.
The MDAC2's signal path in balanced mode is technically elegant and simple yet "beautiful" (says the designer)
Recent tests of the MDAC2 design with balanced operation achieved -132dB Dynamic range, I expect about -134dB to -135dB with the final PCB, this is the industry's highest performance DAC.
SE was nearer 125dB (still extremely good - but its a shame to now you could have better results with Balanced operation).
