JohnW
pfm member
This would save me some work over having to build a analog lowpass filter but i think i will have the bass in stereo.
BTW: i do not really see anything wrong in using analog active XO, if you are worried about SQ degradation you can always buy the vishey Z-foil resistors and since there already is 33 resistors used in the mdac2(if i remember correctly) adding 2...4 per channel should not make any difference.
MDAC2 only requires x4 ZFoils (and x4 more for the analogue attenuator versions) ... Might have been x32 for the original MDAC...
I'd worry more about the capacitors then resistors of an XO.
