I also prefer the wireless stuff in the streamer box.
Like the idea of the HQ MDAC2 PSU in the streamer box.
+1 - It also means that I can abandon the idea of building a new PSU.
Connector arrangement on the lower Analogue PCB:-
Stereo Balanced Headphone output - 5W Miniature Male XLR
Is there any disadvantages to using DoP for compatibility? It is just a data packaging convention that doesn't alter the bits in any way.
Still really not decided if we will include the original idea of BT on L2 and wireless USB on L3 units now that we have a streamer solution - I'll consider everyone's feedback on this...
From my experience, if you like to have flash media support in a system without connected keyboard and mouse, you have much more offers within WinTel.
And if you want to have pure DSD transmission (and not DSD over PCM), my understanding is that you need WinTel also.
If you are flexible with the ingredients (streamer, CD-Transport, HQ-PSU ) of the second MDAC housing, is it possible to offer just CD-Transport with HQ-PSU?
Didn't you say for HDMI you have to spend thousands of $ just for the licence?
I like the idea of dropping Bluetooth from MDAC2 L2. I prefer as simple as possible DAC without any unnecessary and possible disruptive elements. The attenuator is a must though. That is why I am planning to go for L2 instead of L1.
Hi John, I understand that the rear panel is hard pressed for space. The original design (as on the wiki) was for a 4Way Female XLR balanced headphone connection:- 1 left +, 2 left -, 3 right +, 4 right -, (Shell Ground), which is sort of an unofficial standard used by many headphone amp manufacturers. I guess since you are going with a miniXLR, may as well use a 5-pin connector for a proper pin to be used for ground, and to revert to the standard where output is male XLR.
In case if space miraculously appears for any of the miniXLR to be upgraded to full-sized XLR, please consider the balanced headphone out.
Leon
John,
Re: VFET MB, Many thanks for the detailed reply, it sounds great (excuse the pun)! Will it borrow the power supply fully from the 8200MB? Does that include a protection circuitry?
Tony
John,
As the L4 design is to be repackaged could you please consider including the 20dB attenuation into the L1 design? Am I right to think the costs/features ATM are (for Toy/Fusion MDAC owners):-
+ shipping + fusion option + donor MDAC £370
- MDAC2 L1 £250-300 FPGA filters, dual ESS9018, RCA AV bypass, XLR headphones, Toy resistors, DSD/DXD (embedded PCM), galvanically isolated USB Audio Class 2 up to 32bit/768kHz
- MDAC2 L2 £400-450 L1 + DSP, bluetooth, 20dB attenuator, advanced clock, ASRC free SPDIF
- MDAC2 L3 £550-600 L2 + DSD/DXD ADC, preamp/RIAA EQ, USB wireless, word clock/video clock sync
- MDAC2 L4 £??? streamer
For MDAC owners with no previous upgrade + £300 development costs.
Did you mean bluetooth and wireless functions will be removed from L2 and L3 and be added to L4?
Many thanks
The Advanced clock option of the L2/L3 is also significant in SQ terms.
Not sure that I like the idea of moving agreed functionality of the L3 version to what is now becoming a totally independent L4 version. If you do not want the L4 version you have lost the functionality. This constant moving of goal posts to satisfy just one or two people is a bit of a concern.
I may have been interested in the MDAC2L4 version but as a separate box probably not.
A standalone CD solution would be a totally different design mechanically and electrically from a Streamer solution - for a CD solution we would use the Metal body Car Mech, while for the streamer we would use a "Laptop" type drive just to extract the data.
Ok, but Bluetooth is not, I suppose.
Are you saying you will offer a streamer / Cd- Transport (with a laptop type drive) and the MTRN (with Metal body Car Mech)?
Or is the MTRN dead with upcoming Streamer / Cd-Transport?
MTRN would be dropped if we released the streamer -.. each would extract the Data Bit perfect.
Its the cd player mechanism that is used inside the unit.. Very high quality part going from previous discussions around it.
