Low cost ,high quality sound speakers for time being
Discussion in 'audio' started by winiar550, Aug 5, 2022.
  1. winiar550
    winiar550 Well-Known Member
    As in the title I am looking for an advice from experienced pinkfishers for recommendations of cheap second hand speakers which will hold me for time being before make a final decision on the proper ones.
    I am using a Devialet expert 1000 pro ,room dimensions are around 4x4m so around 16 Sam
    My amplifiers are very dynamic,neutral and fast also very detailed.
    I like neutral sound but also slightly warmer midrange ,detailed ,dynamic ,with very controlled and dynamic base and clear but not harsh highs.
    All advice highly appreciated.
    Thank you.
  2. linnfomaniac83
    Ruark Talisman 2, Linn Katan, Linn Ninka, anything from Neat.
  3. winiar550
    Thanks.
    Are these comparable to something like monitor audio gs20 or totem arro for example?
  4. Gervais Cote
    Gervais Cote Predator
    Bookshelf ported Proac with a 6 1/2 woofer and soft dome fabric tweeter would come to my mind.
    linnfomaniac83 likes this.
  5. ChrisS
    ChrisS Well-Known Member
    What is your budget?
    Tarzan likes this.
  6. winiar550
    Max £1000
  7. winiar550
    I just don't want to hurt myself too much after owning focal sopra 1 and diablo utopia lll....
  8. linnfomaniac83
    Yes, I’d say so. The Katans are compact stand mount speakers so definitely won’t have the bass weight of the GS20s… the Ninkas will though, and they’re detailed at the top end without getting harsh or aggressive. The Ruark Talismans are very nice too, clean punchy bass, open lively mids and well behaved treble… they fall a little short of my active Ninkas in terms of bass weight and top end detail, but they’re easy to drive and lots of fun. I have a pair on a Naim system. Similarly, Neat speakers tend to be punchy, lively and open without being aggressive.
  9. ryder
    ryder pfm Member
    At your price range,
    Dynaudio(neutral to warmer)
    Proac(neutral to brighter, lean bass)
    Harbeth(warmer, fuller and looser bass)
    Not sure how they will match with your Devialet 1000 Pro though.
    Rockmeister likes this.
  10. hifi-dog
    hifi-dog pfm Member
    Atc?
    AndyU likes this.
  11. topa
    topa Sans CDPs
    I'de look through the list of speakers on the Devialet SAM list, and pick out the cheapest?
  12. andrewd
    andrewd pfm Member
    Salamander likes this.
  13. flutteringwow
    flutteringwow I am a sound quality evaluation device
    Q Acoustics Concept 30.
    You wont find better for the money.
    https://petertyson.co.uk/q-acoustics-concept-30-standmount-speakers
    If you can increase budget, there is a set of Concept 300's on eBay. These are my lifetime speakers (albeit in Grey) and are spectacular.
    https://www.ebay.co.uk/itm/28488808...d=link&campid=5338728743&toolid=20001&mkevt=1
    (just confirm they come with their designated stands as they do when brand new as have to be used with them and you will want to use them as they look great )
    https://www.the-ear.net/review-hardware/q-acoustics-concept-300-standmount-loudspeaker
    Or if you want floorstanders, Concept 50s
    https://www.ebay.co.uk/itm/18552706...d=link&campid=5338728743&toolid=20001&mkevt=1
    https://the-ear.net/review-hardware/q-acoustics-concept-50-floorstanding-loudspeakers
  14. NickofWimbledon
    NickofWimbledon Well-Known Member
    Near Iota Alphas for less than £1K on EBay…
  15. leroyd
    leroyd pfm Member
    I had Q acoustic 40 floorstanders in my set up and they are superb value for money
  16. Jodet
    Jodet pfm Member
    Wharfedale 12 series.
  17. JezmondTutu
    JezmondTutu pfm Member
    Ruark Crusaders. Way under a grand and you’ll sell them on for the same. Agree Talisman’s are amazing for £200-250.
    Dynaudio Contour 1.8’s. I loved my 1.1’s but have used both.
    Or stretch your budget and get some ATC’s which will also hold their value.
  18. linnfomaniac83
    It’s findings Crusaders that’s the challenge… also I’d look for MK2s, they’re the best variant in my opinion, by a decent margin. Wonderful speakers that can and do hold up in a serious system today.
    I do adore my Talismans though, they’re in an “budget” Naim system and it’s definitely more than the sum of it’s parts. I’d love to try them in a more serious system!
    JezmondTutu and lawrence001 like this.
  19. lawrence001
    lawrence001 pfm Member
    Where are you based?
  20. JezmondTutu
    I used Talismans in my main system for ten years and they were great.
    AnilS and linnfomaniac83 like this.
