There are a lot to choose from - Yamaha, Marantz, Pioneer, Sansui - and the European ones that are not nearly as commonly mentioned such as Tandberg, Uher, Nordmende etc, most of which never get a look in.
Just bear in mind they are no longer cheap, and before you buy, you should have someone lined up who can fix them for you when something dies in it. That sounds like I'm trying to put you off, but the reality is that it is likely something will die within the next few years in them (unless completely refurbished, which will of course mean top dollar price) and then you either have a big doorstop, or someone lined up to fix it.
Given that, it seems sensible then to buy one that has lots of information on repair already. This means Marantz, Pioneer in pole position, followed by Sansui and Yamaha. If you want to check this out, just do a search on youtube for "[yourchosenmodel] repair". If there are lots of videos then you can sure there is lots of info out there.
