I have a set of... I think, around 1988 Isobariks which have Active and Passive connection options on the rear ( 2 on the left passive, 6 remaining for the Active option ).
The setup currently consists of:
Avondale component power amplifier units, with three NCC200 units in each case (instead of 3 x NAP 135's per channel)
Avondale Power Supply box with three power supplies therein... (in stead of 3 Hi-Caps), but currently using two of the units)
Naim NAC-102 Preamplifier (connected to one of the supplies in the above unit)
Naim Naxo 3-6 which appears externally to be standard... again connected to one of the power supplies
Naim CDSII CD player and NA-XPS power supply
Linn Isobariks PMS/DMS speakers (on Mana Acoustic stands)
It all seems to work fine with the Naxo leads plugged in to the power amps currently, using speaker cables plugged into one of the power units in each of the two power amplifiers, then into the passive speaker connections... but I cannot seem to get anything to make a sound if I connect three sets of cables to each amplifier?!
Have checked and am using the equivalent of the 'SIX-PACK CONNECTIONS' correctly, but it appears the issue is between Power amplifiers and speakers on the Active side...
NB. I have two external crossover units which I have no clue what to do with, but assume they are possibly the key, but I just don't want to rink making any dubious connections and potentially blowing amps, etc. I have not explored the speaker cabinets to see if there are any other crossovers in the base of the cabinets, but am sure my good friend, who built this equipment (now very sadly deceased
) would have had this all sorted (he was cleverer than I...and experimented a lot more).
Please help if you know what I should be doing? Any positive suggestions and diagrams would be very much appreciated. If it helps I could send some photos (how do I insert images from my library on here, as it seems to want links)?
Thank you in advance.
![Pleading face :pleading_face: 🥺](https://cdn.jsdelivr.net/joypixels/assets/7.0/png/unicode/64/1f97a.png)
