Hi, so are you saying that the external crossovers I have...are the likely problem-solver and will sort the Active setup?Hmmm... looking at this, I think I am out of my 'comfort zone' by a fair amount. I'm concerned about de-soldering and re-soldering these wires...
Hi Stuart, you do have a point.I would just use them with the preamp, one power amp and a preamp power supply if you don't know what you are doing. Way less risk of blowing up your tweeters for the uninitiated.
you can then sell on the other kit for a nice wee sum.
Rgds
Stuart
You will need to get the wiring in the base of the Isobariks sorted in order to use the external crossovers but then yes you are part way on the way to getting the system working actively.Hi, so are you saying that the external crossovers I have...are the likely problem-solver and will sort the Active setup?
