Well, the GL85 arm doesn't have a decoupled counterweight to sag all over the place. I'm also pretty sure it doesn't use v-blocks. All in all, a fairly sizeable improvement over the GL75's rather 'flexible' arm.
Not sure what you mean about the servos - the deck is belt drive! Are we talking at cross purposes here?
Finally, the platter is not that light! Sure, it's not as weighty as a GL75, but it still weights about the same as, for example, an LP12.
As I said before, the deck is a well-built and well-designed piece of kit. Whilst the GL75 can be upgraded to a very high level of performance, in it's basic form it has a few weak points - flexible baseplate, arm prone to sag, rattly v-blocks etc. The GL85 was probably better in 'stock' form but probably has less potential for upgrading.
As for the TD125, well i'd say that you pays yer money.....
Cheers
Adrian
Cheers
Adrian
