Hi-Fi And Music Source reviews Naim's
NAC-N 272 Streaming Preamplifier
http://www.hifiandmusicsource.com/2015/11/naim-nac-n-272-streaming-pre-amp-2/
You're a nobody without a Naim
Naim NAC-N 272 streaming pre amplifier
The
NAC-N 272 combines our latest innovations in digital audio technology with classic analogue preamplifier engineering. It samples the best of both worlds to create an immensely musical hi-fi system.
Paired with a
NAP 200, NAP 250 or even a
NAP 300 power amplifier, the
NAC-N 272 is an ideal choice for those seeking the convenience of a single box streaming system with iOS and Android app control, but that crave hi-fi separates performance. It boasts an impressive array of inputs including high-resolution (up to 24bit/192kHz) UPnPTM streaming, Spotify Connect, iRadio, Bluetooth (aptX), USB, multiroom and an optional DAB/FM module. Six digital and three analogue inputs cover integration with a wide range of sources from CD and games consoles to phonostages. It’s also performance upgradable with the addition of a
Naim XP5 XS, XPS2 DR or
555 PS DR power supply.
All this functionality does not come at the cost of performance. The
NAC-N 272 has been carefully designed and meticulously hand-crafted to deliver a completely immersive and awe-inspiring music experience.
Features
- High quality preamplifier including digitally controlled analogue volume control
- UPnP-enabled to allow streaming of audio files at up to 24bit/192kHz resolution from Naim hard disk servers, network-attached storage (NAS) devices or any home computer
- Performance upgradable with XP5 XS, XPS or 555 PS power supply
- Supports a broad range of music formats: WAV, FLAC, Apple Lossless, AIFF, AAC, DSF64 and DFF64, Windows Media-formatted files, Ogg Vorbis and MP3
- Six 24bit/192kHz-capable digital inputs (S/PDIF) to support optimum connection to external sources
- Spotify Connect built-in to stream millions of songs from the world’s most popular streaming service
- Bluetooth connectivity with aptX audio codec
- Optional DAB+/DAB/FM radio module
- vTuner 5* full-service internet radio
- Multiroom & Party Mode compatible
- Naim app for iOS and Android
Hand-built in Salisbury England
All analogue input sockets on the
NAC-N 272 are individually hand wired to the main board to enhance mechanical decoupling. The board itself is mounted on a system of shoulder bolts which releases any tension which can adversely affect sound quality. The sound critical resistors used arrive at Naim matched to within 5%. This already high tolerance is improved before assembly by hand-matching to within margin of just 1%. We then go even further by introducing a slight mechanically compliant bend in the legs of each one during assembly. We take this care and attention because we know it can help to make the difference in producing the incredible sound on which we’ve built our reputation.
Hybrid Volume Control & Class-A Headphone Amp
The
NAC-N 272 volume control is derived from the design of the flagship
Statement NAC S1 control. It offers smooth operation and perfect level match*ing while a Class-A single-ended headphone amplifier makes the most of high-performance headphones. As soon as headphones are plugged in, the output current drive is automatically turned up five times to give dynamic drive for all headphone impedances.
Technology & Craft
Analogue Preamplifier
The
NAC-N 272 is a high-performance Naim preamplifier with quality hand-matched analogue components selected after listening tests. Great care has been taken to protect the signal path from sources of interference. The digital and analogue sections of the product communicate using optical isolation chips which minimises the impact of the noisy digital circuitry and power supply on the critical audio components.
Digital Technology
The
NAC-N 272’s digital pedigree is formidable. It shares the incredibly powerful DSP (Digital Signal Processor) used by the reference
NDS Network Player and features Naim’s proprietary digital audio buffering and filtering techniques. This helps to eliminate jitter and optimises the audio stream for the best musical performance from any digital source. It also means that the
NAC-N 272 can play back DSD64 files.
Naim NAC-N 272 streaming pre amplifier, Naim NAP250.2 power amplifier, Raidho Acoustics X-1 loudspeakers and two JL Audio E-110 subwoofers at Musicraft
https://www.facebook.com/MusicraftUK *****
Rick @ Musicraft
