I have just bought two used REL Strata 3 subwoofers, which I now want to connect up to my Linn/Naim system.
I have, Naim olive 250, 72, hi-cap. Linn Isobariks (very late ones in black) that have crossover in the stand i.e. on back of bricks there are six banana sockets. On the crossover that is in the stand, there are the usual three leads coming out for bass, mid, treble, each with two banana sockets on, which plug into my bricks. Also on the crossover, I have the two banana sockets where I plug my speaker cable in, from the naim amp.
Now, I understand (from REL) that the best way is to use High-Level input into the subs, coming from the speaker output on amp, or from the speaker end. Now, as Naim has this 10ohm issue hence needing 3 metres of speaker cable per side, I have decided to come high-level from the speaker end, to the subs. But, if I buy two standard Neutrik Speakon High Level Leads with the Neutric socket on one end, and the yellow, black, red wires on other end.
There are two pictures here. Ignore arrows drawn on cross-over, I grabbed this image off web, saved me pulling mine out of base to photograph it:
First link is crossover showing banana sockets. I use only one set to plug my speaker cable into:
http://www.nigelcooperauthor.com/misc/bricks-crossover.jpg
This next pic is back of bricks showing speaker cable from crossover going into bricks:
http://www.nigelcooperauthor.com/misc/bricks-back.jpg
As you can see, there is no binding post on crossover where I can wrap the subwoofer three wires from the Neutrik cable, and my banana plugs are soldered onto speaker cable (naca5) and is impossible to get Neutric wires into them.
Any suggestions?
Oh, finally, I know I could come out of my Naim hi-cap Low-Level, but the cable company want £80 per cable to make them up with the Naim 4-pin din on one end and two phonos on the other. That is the only reason I'm not doing it that way. Also, if I did it this way, I need a 4 metre lead for one, and a 3 metre for the other. Going high-level from speaker end means I need just one 1 meter and one 2 meter.
Thanks for advice guys. I await your replies before getting cables put together.
Any suggestions?
