JensenHealey
Air source heat pump might get enough temperature. Will use less electricity - but yer gotta put up with the fan noise.
Far, far better value would be to use solar-thermal - evacuated tube collectors, a couple of sq.m should provide most if not all the heating needed. NB these can go on the roof , or on vertical walls exposed to the sub - the tubes are rotated within the mount to each to face the sky.Air source heat pump might get enough temperature. Will use less electricity - but yer gotta put up with the fan noise.
Do these hot tubs not use Air Source Heat Pumps, or is that extra cost?
It doesn’t feel cold when you get in at all, just comfortable
Tempting for myself… off for my early afternoon swim shortly, the pool is 29°c, which to me is more than warm enough… makes me laugh when people start bracing and complaining it’s cold as they dip their toes… they should try an open water swim in March!you need to fill it with ice cubes then
Would these be suitable on a flat roof? I live in a Dorma bungalow and have plenty of flat roof space, less sloping. My garage is an outbuilding but in a perfect position for PV panels so I’m looking into installing those on the garage roof… be nice if I could be almost self sufficient!Got three of these, sourcing replacement tubes is a bit of a pain:-
Regards
Richard
(yes I’m a keen and competent swimmer, currently doing between 1.5-2 miles daily)
See also: exercise bikes.
29°c is okay, ideally I’d like it a bit cooler, but that’s what it is, and I’m addicted to my swimming. I could do 5km no problem, apart from time… I wouldn’t cover 5km in 90 minutes, which is about my limit time wise… unless I broke it down into two sessions. I think id be able to cover more distance in the time I have if it were a bit cooler!Yes done a bit of open water. I was swimming about 5km on a daily basis in my heyday. To this day i hate a warm pool which is why i stopped going to the local one.
I could put some gradient on them anyway, I have a large amount of un-shaded flat roof space to the rear.They would need to be on a slope of some kind as the tubes rely on hot gas migrating to the top of the copper tube within, I honestly don't know what the minimum would be.
Edit - Just seen Martin's post - I'll bow to his greater knowledge.........
Regards
Richard
Cold tub.Hi pfm massive
My wife and daughter have decided we "need" a hot tub in the garden, I am less convinced but rather than adopting a victorian dad "forbidden" response right out of the box, am going to do some research.
It will need a base building where the location has to be, and style would be more Norwegen/Japanese wooden style hot tub rather than a full disco Jacuzzi although some bubbles have been requested.
Any on here have one, key considerations, costs, concerns? Do they need a water treatment plant in a nearby shed or are they self contained? How much hassle are they, can you leave them full for a long time?
Thanks for any advice.
