Hi,
Thanks.
The fact that the PWM is an asynchronous PWM, does not stop the output signal being classified as a digital signal. There are many asynchronous digital circuits. They are never classed as analogue because they are asynchronous.
From the wiki page :
https://en.wikipedia.org/wiki/Pulse-width_modulation
Pulse-width modulation (
PWM), or
pulse-duration modulation (
PDM), is a fancy way of describing a digital (binary/discrete) signal that was created through a
modulation technique, which involves encoding a
message into a
pulsing signal."
It clearly states it is "
a fancy way of describing a digital (binary/discrete) signal". So even the wiki page describes PWM as a binary/discrete signal - which meets the criteria for being a digital signal.
A digital signal is defined by the permitted levels, which are discrete, and as per the wiki links above in another post (discrete space, digital_geometry, digital_signal), the output of the class D amplifier is indeed, digital.
Regards,
Shadders.
