gintonic
50 shades of grey pussy cats
Garador
that was the brand my neighbour had levered up in the corner to gain access
Garador
Opened our tired old up-and-over garage door yesterday to put some stuff in the car, and the bloody thing failed and refused to shut. Tried for about an hour but it wasn’t having any. Ended up dismantling it and screwing the door to the inside of the frame, for security.
So, we need a new (single) garage door. Options seem to be another up and over (not keen, this one was always crap and I’m not after another the same. The basic design looks cheap, unless there are well-engineered options for sensible money?); a roller shutter (don’t want it to look like a shop front, and not sure whether you need more room for the roller); or a slatted jobby which rolls up and over. Any benefits/pitfalls the pfm massive can flag up? Also, GRP or steel?
Prolly not looking for a really long term solution as we may reconfigure the garage at some point and need a different opening then anyway, but need >5 years of durable and reliable use, with sensible security.
Thoughts?
Old Garador doors say pre 2000 weren’t great
Those garage door “Defenders” that bolt to the ground also help but also advertise “ I have something of value in here”
I moved into my house in late 1976 The integral garage was fitted with a Henderson Merlin door. It's galvanised steel. It worked well until Mrs Mull missed the brake pedal when I was teaching her to drive and rolled into it. She severely bent and fractured one of the side channels, which provide much of the door's rigidity. I used an allen key to 'peg' the large spring which drives the mechanism, removed the door and repaired the side channel with a combination of tin bashing and a pop riveted and soldered patch, all on the inside.
Put it back together and all was well.
The door continued to work well until one of the side cables snapped, due to corrosion from lack of lubrication. My fault. I bought a pair of new cables from a garage door specialist in St Helens and fitted them. It's a ball ache, but not difficult. I now make sure the cables and the side 'runner' rails are sprayed with a 'moly' type lubricant at least yearly..or at least when I remember.
The latch release cable broke a year or so back. I called a local company and found I was speaking to one of their employees in the next village. He told me he could supply me a cable if I popped round. He had the cable ready in his porch and refused all offers of cash.
Finally... after 45 years.. the keys were getting very worn. A friend, fellow audiophile and locksmith provided me with new keys..F.O.C.
The door has been assorted colours since installation, ranging from bright yellow, through mid blue and black. When we got a nice new dark blue Rockdoor, I obtained the RAL (colour code) number from the supplier. It was no bother to get B&Q to make up matching paint for the garage door.
As far as I can see, the only people around here who have changed their garage doors, are those with loadsacash. All of the others are still functioning.
Definitely need a new door. I had to get a bit medieval on its ass to get it un-wedged. Also, it was always crap, so a cheap repair to a crap door will leave us with a crap door, which I never had much confidence in at the best of times. Time to bite the bullet. Lots of love for Hormann on here, and there's a local installer. I'll give them a shout.I very much doubt you need a complete new door. What make is your current door? What's wrong with it? How bad is the damage ?
I have a 40 year old Henderson basic "Up and Over" garage door which, while it may not be the greatest door in the world, it's perfectly serviceable despite Henderson having gone out of business years ago. I've just had mine serviced, including springs re-tensioned etc. for around £80.00, much cheaper than a new door!
Good idea the weight of the Harley should keep any one from stealing his garage.Yep. Friend of mine with many £k of Harley in hs garage had no fancy locks, but his bike was secured with mighty chains to massive steel 'ragbolts' in foot deep concrete.
Pete
Management has decided we’re moving from a canopy style up and over to a pair of side hinged doors. I agree, and we like that you can get them in a 1/3 - 2/3 split. So the search for a decent local supply and fit resumes next week.
