Stunsworth
Just one last question: how good is its gapless playback?
It's gapless.
Thanks guys, yes I did look at a Mac mini. I've had a look at a couple of the cheaper Hackintosh things and one of these might fit the bill but again I'm not computer savvy. I would like to stick with Mac OS though so I can have everything tied together.
I'm not skint but it'll be a while before I get back to work so I'm reluctant to spend unnecessarily. I'm a bit of a hoarder so maybe I should flog some gear off.
The G5 will run Snow Leopard.
unfortunately it won't. the last os the ppc models run is leopard
I have a G4 with SL running on it.
Cheers,
DV
I couldn't agree more.
Having a good old clean-out followed by a wise HiFi decision reaps heaps of happiness
Peter
Well perhaps if you can show Chops how to do that, all will be well.I have a G4 with SL running on it.
Cheers,
DV
Cheers,
DV
You must have magic powers DVSnow Leopard will not run on any PowerPC system, even PowerPC G5 systems that are 64-bit capable. If you have a PowerBook G4, iBook G4, PowerMac G4, Mac Mini (G4), iMac G4, iMac G5, or PowerMac G5, do not buy Snow Leopard since you will not be able to install it. Apple has split away from PowerPC, and while there are technical reasons for why the 64-bit architecture in the PowerPC will not work with the latest OS, the fact that Apple has switched architectures is the primary reason for the drop in support.
From cnet
Snow Leopard PowerPC Support: NONE!
My new dac has arrived ( thank you tinturkey ) I made up a 75 ohm cable this morning and it's singing away fed from my AAA5. It sounds a bit harsh to me atm so I'm going to leave it playing for a while. Camera kit for my ipad should be here tomorrow so I just need a decent short A to B usb lead. Now then this being a digital signal should the quality of the lead be important or does it just need to be fit for purpose? I laughed my bollox off last night when I saw a fancy usb lead for 335 quid Should I just go for a two quidder or should I push the boat out for something with a bit of gold plate for less than a tenner?
A decent quality Beklin should fit the bill. Well made and well priced.There are a few choices in the range.
