PMC seem to change their range every few weeks
This gave me a chuckle. Not far from the truth either!
I had a long chat with PMC rep at Bristol show in Feb.
They have made a lot of changes to the new 5 series and I felt it was audible.
They look like the old model but they changed the tweeter. Changed the cross over using the design from Fact 12.
They changed the internal air flow system within the cabinet and braced the stand with solid stainless steel bars for strengthening the speaker at the base.
The rep said the bass unit is the same and so I believe is the cabinet.
I have never much liked the 5 series and don't usually give the PMC room more than 5 minutes at Bristol.
Not so this time. I sat listening to many different tracks through the 5.24's.
They have finally got the highs and lows controlled, at least playing through some huge Bryston amplifier, which resembled the skip sitting on my drive, in size.
With speakers and the sort of money you are thinking of paying, it wouldn't be difficult to achieve a top quality sound.
Simply because a good quality speaker can work really well, if it works in your system, in your room. It doesn't necessarily have to be at the top end of the range or your budget.
Oh and I'M gonna be mischievous and suggest giving the Harbeth XD range a listen.
I coudn't get enough of their room.
The C7es- xd also have revised cross over and open the speaker right up.
These are on my most wanted list.
