James
Lord of the Erg\o/s
I appreciate heavy loudspeakers are a PITA to move around. My Yamaha NS-1000Ms are almost hernia-inducingly heavy too. But they are heavy for good reason.The other factor which I don't want to think about (but have to) is weight. Passive Fact12's weigh about half that of active SCM50's, which is something to think about when you need to shift them around!
[Edit: I did the easy maths and I was wrong. The SCM50's single woofer has about 1.5 times greater area than the Fact12's two.]
On driver sizing, it's easy to be fooled into thinking two smaller drivers make up for a big one. Even if they offer identical swept areas, the bigger lone driver will couple with the room air mass more effectively than multiple drivers with the same displacement.
