yes,is slowly when return in position......Do the bass units recoil slowly when pushed in by hand?
If they return to position slowly then they are sealed OK.
^ sounds right.
Its not clear how close the SBLs are to the wall behind - how close?
M
The pads are important. Also important to fill in the holes in the wood with Ronseal High Performance wood sealer before replacing new pads. You will need pads, staples, silicone. etc.[/QUOT
i try to rebuild one more time the SBL's with new pads and fills the old holes with ronseal....
I didn't think Naim speakers were renown for their bass qualities? that's why nobody likes them. It's the whole flat earth religion innit.
Start at the bottom with the spikes. Make sure they penetrate the carpet and touch the wood floor, whilst making sure the cabinet is as low as possible. If the cabinet is too high above the floor then bass suffers.
ok..new gasket kit and new spikes
michael is near near on the wall.....This does not show how close they are to the back wall.
But how near are they?
If anything more than say 10cm, bass is likely to suffer.
